[ +/- ] [ Τώρα είναι Πέμ Οκτ 22, 2026 05:24 ]
Προβλημα στο PC μου
Προβλημα στο PC μου
Δημοσίευσηαπό Nasos Mazdaspeed 6 την Πέμ Ιαν 30, 2014 12:20
Παιδια,μια βοηθεια παρακαλω!Δευτερη φορα μεσα σε 3 μηνες που...ΜΟΥ ΕΒΓΑΛΕ ΜΠΛΕ ΟΘΟΝΗ titanic
Εχω τα 7 Ultimate και αυτο που κανει ειναι το εξης:
Κολλαει ο κερσορας για λιγα δευτερολεπτα και μετα μου εβγαλε μπλε οθονη με hardware problem occured!
Να ειναι η καρτα γραφικων?να ειναι μηπως το τροφοδοτικο?
Το μηνυμα που μου εβγαλαν τα Windows οταν ξαναμπηκα ηταν αυτο:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1032
Additional information about the problem:
BCCode: 124
BCP1: 0000000000000000
BCP2: FFFFFA8004B76028
BCP3: 00000000F2000040
BCP4: 0000000000000800
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\013014-18470-01.dmp
C:\Users\Nasos\AppData\Local\Temp\WER-89450-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Re: Προβλημα στο PC μου
Δημοσίευσηαπό pankrok την Πέμ Ιαν 30, 2014 12:25
http://www.tomshardware.co.uk/forum/350 ... sod-bccode
Your first error appears to be caused by an actual BSOD from the ntoskrnl.exe. Do you have a Win 7 DVD that you could try doing a repair on your system?
The second BSOD appears to be caused by your Video card drivers "atikmdag.sys". Can you try deleting your drivers, and installing a fresh copy? You may need to sweep your system of old drivers first though. I believe driver sweeper can do this.
Lastly, your 3rd BSOD is related to your Hardware Abstraction layer (hal.dll) and the ntoskrnl. So one of the pieces of your hardware does not seem to agree with what you were doing. This can point to a few things - possibly BIOS problem, or even something wrong with your HDD (bad sectors possibly).
Open up your command prompt as administrator - and type this in sfc /scannow
Δημοσίευσηαπό Nasos Mazdaspeed 6 την Πέμ Ιαν 30, 2014 12:29
Ευχαριστω φιλε Πανο!Αν ειναι ΒΙΟS τι μπορω να κανω ?
Για σκληρο δισκο θα το προτιμουσα αν και μολις εδω και 1,5 χρονο αλλαξα,γιατι τωρα θα πηγαινα σε SSD yiiiio
Καρτα γραφικων εχω μια πολυ καλη για τοτε το,2010 που την ειχα παρει!Ειναι η GTX 550 ΤΙ .
Δημοσίευσηαπό slioumis την Πέμ Ιαν 30, 2014 12:35
Νασο θερμοκρασιες ελενξες?
αν ναι τρεξε ενα προγραμμα για να ελενξει το σκληρο σου δισκο και ενα για να δεις την κατασταση στη ram σου!
τα δυο που σου εστειλα σε pm ειναι free και αρκετα αξιοπιστα.
Το προβλημα εμφανιζεται μετα απο πολυωρη χρηση?
επισης κανε μια αναβαθμιση τους driver σου.
και αν εχεις γνησια windows κανε ενα forrmat αφου πρωτα ομως παρεις ολα τα χρησιμα αρχεια σου.
Τελευταία επεξεργασία από slioumis και Πέμ Ιαν 30, 2014 12:38, έχει επεξεργασθεί 1 φορά/ες συνολικά
Δέκα ζευγάρια λάστιχα αλλάζω κάθε χρόνο,
γιατί γυρνώ τη Νάουσα με μπάντες μόνο!!!
slioumis
Τοποθεσία: ΝΑΟΥΣΑ
Ηλικία: 30
Μοντέλο Αυτ.: MAZDA 6 MK2 fl
Δημοσίευσηαπό Nasos Mazdaspeed 6 την Πέμ Ιαν 30, 2014 12:36
Τα κατεβασα Στεργιο μου τα αρχειακια και πολυ συντομα θα τα τρεξω!Ευχαριστω :bow:
ΟΠχι,καθολου μετα απο πολυωρη χρηση...φαντασου οτι 1,5 ωρα τον ειχα ανοιχτο!
Επισης...και τις δυο φορες μου το εχει εμφανισει οταν ειμαι στο ΦΒ και χωρις να παιζω παιχνιδια!!!
Δημοσίευσηαπό Nasos Mazdaspeed 6 την Πέμ Ιαν 30, 2014 13:29
Μεχρι στιγμης Στεργιο,στο 52 της ram που ελεγχει,κανενα προβλημα!
Δημοσίευσηαπό Nasos Mazdaspeed 6 την Πέμ Ιαν 30, 2014 14:34
Τελειωσε χωρις κανενα προβλημα !
Ακομη το HDD scan με εβγαλε πρασινο σε ολα...μαλλον δεν ειναι σκληρος για αρχη?
Δημοσίευσηαπό The Ace την Πέμ Ιαν 30, 2014 14:47
Συνήθως τέτοια resets/BSODs γίνονται λόγω ρεύματος (ή απουσίας του), δηλαδή τροφοδοτικό ή κάποιο molex. Βέβαια οτιδήποτε μπορεί να έχει χαλάσει, π.χ. έκανες κάποιο update και άρχισες να τα βλέπεις αυτά ? σου το κάνει και αλλού ? έχεις δει κάποιο άλλο σύμπτωμα ?
Δημοσίευσηαπό Mazdaspeed Club την Πέμ Ιαν 30, 2014 17:06
Οχι Αντωνη,τι update να κανω και που?οτι επιτασσουν μονο τα Windows η οι αναβαθμισεις της καρτας γραφικων!
Οχι,κανενα αλλο συμπτωμα,μονο αυτο που περιεγραψα!ρι ειναι τα Molex?
Mazdaspeed Club
Μοντέλο Αυτ.: Mazda
Δημοσίευσηαπό diMiPS την Πέμ Ιαν 30, 2014 17:07
οπως ειπαν και οι προηγουμενοι εαν εισαι σιγουρος για το software που εχεις εγκαταστησει , συνηθως οι BSOD η blue screens of death (ελληνιστι) προκαλουνται απο υπερθερμανση, κακο ή ανεπαρκες ρευμα, καρτα γραφικων
αφου βεβαιωθεις οτι το software ειναι οκ, αρχισε να ψαχνεσαι με αυτα
θερμοκρασιες μπορει ναανεβασει και απο μια κακη η φθαρμενη παστα αναμεσα στη cpu και την ψυκτρα - δεν ειναι απαραιτητο να στρεσαρεις στο full για να ανεβασει θερμοκρασια (αυτο ευκολα το μετρας)
ελεγξε το τροφοδοτικο αν μπορεις και την καρτα γραφικων
αληθεια , χωρις να αλλαξεις κατι σε software κ hardware (το παραμικρο) αρχισε να στο κανει ; η εκανες καποια αλλαγη / προσθηκη ;
αν ναι , τοτε απο εκει ξεκινα
π.χ. αν αλλαξες καρτα γραφικων....
Δημοσίευσηαπό Nasos Mazdaspeed 6 την Πέμ Ιαν 30, 2014 17:29
Θερμοκρασιες Δημητρη εχω καλες,γιατι εχω και οργανακι που τις βλεπει!Ακομη και με απαιτητικο παιχνιδι δεν ξεπερναω τους 40 βαθμους τον χειμωνα!
Φοβαμαι για καρτα γραφικων,αλλα πως θα μπορει να ελεγχθει η καρτα γραφικων?
Καρτα γραφικων εχω αλλαξει απο το 2010 οπως και τροφοδοτικο το 2011...καμμια αλλη αλλαγη!
Δημοσίευσηαπό dancerman την Πέμ Ιαν 30, 2014 19:14
μπορει να φταιει και η μητρικη ρε παιδια , ραμ σπανιως φταινε παντως. Νασο θα πρεπει να το ελεξει καποιος τεχνικος γτ οτι και να σου πουμε διαγνωση χωρις να τεσταρουμε καποια πραγματα δε γινετε. ο δισκος δυτσκολα επισης να εχει χαλασει εφοσον ειναι τοσο καινουριος. Επισης δες στο bios αν εχεις defualt ρυθμισεις.
Δημοσίευσηαπό Nasos Mazdaspeed 6 την Παρ Ιαν 31, 2014 16:35
Ειχαμε Πετρο κανει μια αναβαθμιση στην ΒΙΟS τελευταια,αλλα αυτο οριν κανα 7μηνο...λες?
Αν ειναι μητρικη θα μπορει να συνεργαστει με επεξεργαστη του 2009 και συγκεκριμενα Asus?
Δημοσίευσηαπό dancerman την Παρ Ιαν 31, 2014 20:34
αν ειναι μητρικη θα πρεπει να δεις πρωτον ποια ειναι τι επεξεργαστης φορας και μετα να βρεις αναλογη μητρικη για το συγκεκριμενο επεξεργαστη,ολες οι μητρικες γραφουνε τι επεξεργαστες δεχονται επανω.
Δημοσίευσηαπό diMiPS την Παρ Ιαν 31, 2014 21:33
η μητρικη οταν χτυπα οπως και η μνημη η η cpu 99,99% δεν ξεκινα το pc. και χτυπαει και ηχητικο alarm
το να δουλευεις και ξαφνου να κολαει με blue screen ειναι συνηθως η απο software η θερμοκρασια (που εδω λεει οτι εινια οκ) ή απο καρτα γραφ. (δες μηπως ζεσταινεται η καρτα υπερβολικα) η απο ρευμα
τωρα το τι απο ολα φταιει ....θελει ψιλαφισμα
φυσικα υπαρχει και το 0.01% οπου ειναι κατι εντελως απιθανο - οσο ζουμε μαθαινουμε
Επιστροφή στο PC-Links-PC Tech
