[ +/- ] [ Τώρα είναι Κυρ Οκτ 25, 2026 11:30 ]
SpeedLab 04-up Mazda 3 Power Package
Δημοσίευσηαπό stelios.mazda3club την Σάβ Φεβ 04, 2012 22:11
SpeedLab Mazda 3 Power Packages
http://www.speedlab.com.ph/index.php/mazda/3/mazda3-16
- SpeedLab K&N Cold Air Intake – P11,500
- HotPipes Headers – P17,500
- Unichip Piggyback Computer – P30,000
- Fits 1.6L and 2.0L vehicles
http://www.mazdatech.org/community/view ... 93&t=31897
http://custompinoyrides.com/products/sp ... -packages/
MAZDA 3 1.6L SPEEDLAB K&N MAZDA 3 COLD AIR INTAKE
http://www.speedlab.com.ph/index.php/ma ... iew/42/228
Its a well known fact, cold air intakes make more power. Our cold air intake features a lifetime washable K&N filter, and our own proprietary long tube design. dyno proven 8-10hp gains to the wheels. 100% bolt on installation woth no cutting or altering of the vehicle. Fits all Mazda 3 engines, 1.6L and 2.0L
HotPipes Downpip
http://www.hotpipesheaders.com/applications.php?id=10
Larger and longer primaries allow for proper exhaust pulse scavenging to produce more power with drastically less restriction. Provisions for both primary and secondary O2 sensors insures no CEL problems. 100% bolt on installation. Fits all Mazda 3 engines, 1.6L and 2.0L
Bypass Valve
http://www.speedlab.com.ph/index.php/ma ... iew/42/233
Our air bypass valve reduces the risk of hydrolocking when passing through flooded waters by letting air have an alternate route when the filter head is submereged. Highly recommended
http://www.unichip.us/products/24-Unichip-Q
the Unichip maximizes the gains made by the intake and header by adjuting the car's fuel and spark timing. Additional 10-14hp increase on top of the first 2 mods while also giving better fuel economy, up to 105 in most case. Throttle response is also improved.
Re: SpeedLab 04-up Mazda 3 Power Package
Δημοσίευσηαπό GiannhsAtenza την Σάβ Φεβ 04, 2012 22:54
αντε να δουμε και πρωτη τοποθετηση σε 3αρι ελληνικο!!!!
για εμας τους 6αριδες δεν υπαρχει κανενο τετοιο ετοιμο κιτ?
Δημοσίευσηαπό kalidor την Σάβ Φεβ 04, 2012 23:36
Στελιο ποσο εχουν σε ευρω αυτα...και απο που???
Δημοσίευσηαπό stelios.mazda3club την Κυρ Φεβ 05, 2012 00:35
φιλιππινες ειναι το κιτ
1040.73 euro στο πρίπου
EUR PHP
1.00 = 56.21
loveshower loveshower loveshower loveshower loveshower loveshower
MAZDA 6 2.0L
http://www.speedlab.com.ph/index.php/mazda/6/mazda6-20
Δημοσίευσηαπό GiannhsAtenza την Κυρ Φεβ 05, 2012 11:44
Να γιατι ηθελα και θελω ακομα το 2.0
290 290 290 290 290 290 290 290 290 290 290
Δημοσίευσηαπό Nasos Mazdaspeed 6 την Κυρ Φεβ 05, 2012 12:59
αυτα δηλαδη Στελιο διντοναι πακετακι σε εναν ενδιαφερομενο?
κατευθειαν???ΦΠΕ με ενα τετοιο παρα πολυ λογικο κοστος????
ειναι σαν προσφορα να καταλαβουμε?
σκεφτεσαι να το προχωρησεις? loveshower
Δημοσίευσηαπό stelios.mazda3club την Τετ Φεβ 08, 2012 22:32
μην προτρέχουμε,δεν έχω επικοινωνήσει με φιλιππίνες στο ποσο θα κοστίσει με έξοδα αποστολής,απλός έκανα την μετατροπή τον τιμών μου αναγράφονται στην σελίδα,όσο για τον εγκέφαλο πεζή πολύ από τις αρχές του γενάρη σε όλα τα site kap kap kap
Δημοσίευσηαπό Nasos Mazdaspeed 6 την Πέμ Φεβ 09, 2012 09:51
ο Unichip ειναι γνωστος εξαλλου και μαλιστα ηταν απο τις πρωτες μοντες απο το 2007 ηδη για τον 2,3Τ στην Αμερικη!
τι νομιζω εγω τωρα...αν τα εξοδα αποστολης ειναι πολλα,ακομη και ετσι φθηνοτερα θα ειναι απο Ελλαδα...ισως!
πχ αν εβαζες προγραμμα Ελλαδα πχ Reaction η Μαρκακη η autoveltiosis η οπου αλλου τελος παντων...θα ηταν απο 280 εως 350 ευρω...εξατμιση εχεις ολοσωμη?
φιλτροχοανη εχεις...χταποδι και DP δεν εχεις...οποτε επιπελον εξοδο ειναι αυτο...αρα για βαλτα κατω...τι λες?
Δημοσίευσηαπό stelios.mazda3club την Σάβ Φεβ 11, 2012 22:10
το τελευταίο μου moto είναι μακριά από έλληνες μαστόρους kap kap kap kap kap kap
Δημοσίευσηαπό Nasos Mazdaspeed 6 την Δευτ Φεβ 13, 2012 10:17
δυστυχως Στελιο καποιοι εχουν αμαυρωσει γενικοτερα το επαγγλεμα εδω,ενω πιστευω πως υπαρχουν και ανθρωποι σωστοι,ευσυνειδητοι και καλοι γνωστες του χωρου!
αλλα τους τρωει και αυτους η μπαλα!μην νομιζουμε βεβαια οτι παντου δεν συμβαινουν αυτα,απλα εδω μαλλον περισσοτερο!
τελικα σκεφτεσαι μονο απο εξωωτερικο για προγραμμα τουλαχιστον?
Δημοσίευσηαπό stelios.mazda3club την Τρί Φεβ 14, 2012 22:20
ερώτηση στις φιλιππίνες
Hi I'm a mazda 3 1.6lt gasoline owner in Greece.
I have already installed a similar cold air intake like your's and a moderate catback excaust system.
Could your unichip piggybag ecu be installed in a car with different setup than your intake-catback kit?
Is the programming of the unit going to work out of the box, or fine tunning by a proffessional programer on the specific car is needed?
Could you ship to Greece, Europe? At what cost?
There are a lot of 1.6lt mazda3s in my country but there are no proven and tested upgrade kits for our car...
Thank you in advance,
και η απάντηση τους
We can ship the intake and headers but not the Unichip.
Intake USD 265
headers USD 420
USD 120 shipping for both
Δημοσίευσηαπό Nasos Mazdaspeed 6 την Τετ Φεβ 15, 2012 15:52
για ποιον λογο ομως δεν στελνουν το unichip και να ασχοληθει καποιος εδω?
Δημοσίευσηαπό kalidor την Σάβ Φεβ 18, 2012 16:21
Για αλλη μια φορα αποτυχαμε για βελτιωση....
Δημοσίευσηαπό Nasos Mazdaspeed 6 την Κυρ Φεβ 19, 2012 14:56
οι παραλληλοι παντως η οι αγραφοι εχουν μειονεκτημα πιστευω στις ρυθμισεις,οπου οτι κανεις αυτο ειναι!δεν προβλεπουν για καποια διορθωση πχ να κατι παει στραβα!διορθωστε με αν κανω λαθος!Στελιο,γιατι δεν βαζεις ολα αυτα και να τελικα εχεις θεμα με τον Unichip δεν κανεις ενα ταξιδακι προς τα εδω για Re action η Mαρκακη η autoveltiosis Σωκρατη? :)
Δημοσίευσηαπό stelios.mazda3club την Δευτ Φεβ 20, 2012 14:49
αποστάλθηκε και άλλο mail,ο λόγος που προσπαθώ να έρθω στην συμφωνία για τον εγκέφαλο είναι ότι η εταιρία έχει δυο έτοιμα προγράμματα τα οποια τα τοποθετεί,στις φιλιππίνες υπάρχουν χιλιάδες mazda3 με 1,6L κινητήρα και "τουρπισμενα" από την ίδια εταιρία,έχω γραφτεί και στο club τους και συλλέγω πληροφορίες
όσο για το ταξίδι που λες το σκέφτομαι,και από αυτούς που λες μάλλον στον re acion να παο,είμαι πολύ περίεργος για αυτόν τις mazda pious εκκεντροφόρους βάζει??? επλίζω όχι "πομπισιους"
Επιστροφή στο Hatchback
