[ +/- ] [ Τώρα είναι Δευτ Οκτ 26, 2026 21:20 ]
SPAX RSX COILOVER KIT MAZDA 2
Δημοσίευσηαπό dgiannitakis την Παρ Φεβ 05, 2010 15:25
£528.74
MAZDA 2 - 1.25; 1.4; 1.6; 1.4CD 01/03-05/07 SPAX RSX COILOVER KIT - LOWERS FRONT BY 35-65mm - LOWERS REAR BY 35-65mm - Part No: RSX987
Performance: SPAX RSX kits contain 4 uprated, shortened, 28 stage on-car adjustable dampers, matched to a set of Chrome Silicone race type springs. SPAX engineers have developed these kits to produce total control and razor sharp handling. RSX dampers are uprated, shortened and pressurised with Krypton gas. This ensures that high speed performance is ultra stable, fade free and therefore significantly improved. The result is maximum cornering speed and traction, minimum braking distance and roll. Maximum adrenaline when you want it, minimum adrenaline when you don’t! RSX kits are adjustable for ride height on the car, with no dismantling. RSX is ideal for track days and fast road applications because you can transform your car’s handling and ride height from “drive to work” to “track day” or “show car” in minutes!
Quality: SPAX RSX kits are designed, manufactured and tested to the strictest German TüV quality standards, using technology developed on the race tracks of the world. Each and every RSX damper is fully Dyno Tested to ensure you get 100% performance, 100% quality, 100% guaranteed. All RSX damper bodies and springs are Epoxy Powder coated and oven cured for second to none looks and extra long life. NEW Stainless Steel Height Adjusters and Spring Seats ensure no seized components and long, trouble free life. No plated or painted parts to go rusty and seize solid, no plastic parts. Just 100% high quality stainless steel.
Safety: Dampers and springs are safety critical parts of your car that can save your life. Optimal handling results in better driver control and shorter stopping distances and this leads to a safer and more enjoyable drive.
Ultimate Performance, Race Engineering & Stainless Technology
What you need to know
...about Controlling Ride Height & Handling
If you want the ultimate suspension kit to transform the handling characteristics of your car and to adjust the ride height too, then SPAX RSX is the answer. RSX kits contain all of the key features and benefits of our PSX kits, plus allow you to adjust the ride height of the car using 100% Stainless Steel Height Adjusters. RSX also allows you to set the corner weights of your car, which means you can control the weight distribution, improving the balance and grip of the car. Because RSX is a “Coil-Over” design, it comes with narrower, uprated race type springs, which means you can fit larger diameter wheels.
Controlling the damper stiffness allows you to alter the suspension set up to perfectly suit your style of driving. The result is more driver confidence and this means more enjoyment!
Some suspension kits may give your car cool looks and adjustable ride height.
SPAX RSX Suspension Kits deliver SO MUCH MORE
