[ +/- ] [ Τώρα είναι Δευτ Οκτ 26, 2026 21:20 ]
Bilstein PSS10 vs. KW Variant 3
Δημοσίευσηαπό dgiannitakis την Δευτ Μάιος 10, 2010 10:56
Ποιά από τις δύο επιλογές προτιμάτε και για ποιούς λόγους; ;)
BILSTEIN PSS10
Bilstein’s monotube shocks absorber design controls heat dissipation and ride control. The PSS10 Coil-Over System is an evolution of the PSS9 system.
The Bilstein PSS10 Coil-Over System offers ten vehicle adjustment settings and includes numbered adjusters at the base of the shock body so you know exactly what setting you are on without counting clicks. Set your vehicle low and tight for optimized performance or revert to a more stock-like ride height and handling characteristics.
Ride height adjustments cane made on the vehicle without removing the suspension. The solid aluminum spring seat and lock nut allow a selective adjustment of the vehicle's ride height. Wrenches to adjust front and rear ride height included!
Bilstein monotube gas pressure shock absorbers are manufactured with the rod pointing down into the strut tube, thereby utilizing the thicker body portion of the shock absorber to dissipate side loads. Advantages include greater stability, better road handling, and accurate steering. This combined with extremely high quality manufacturing and materials, means Bilstein will last approximately four times as long as the Original Equipment.
The product's simple, yet exceptionally functional design contributes to the extreme durability and long life of Bilstein Shock Absorbers. Bilstein's shock bodies are precision formed through a unique seamless extrusion process. The shock body is then treated with a special paint finish durable enough to withstand gruelling 240-hour salt spray tests. The finished body is mated with a solid, induction-hardened steel chrome plated and polished shaft, machined valving components and highest quality seals. Bilstein products are backed by an aftermarket lifetime warranty.
KW VARIANT 3
Front: -1.2-2.3” (30-60mm)
Rear: -0.9-2.1” (20-55mm)
The Variant 3 represents state-of-the-art technology for the experienced driver. Separate and independent compression and rebound damping options allow a individual suspension set-up. The 3 individually adjustable components, allow adjustment of the compression of the damper in the low-speed range, while the high speed set-up, so decisive for driving comfort, has been preset by KW engineers.
The unique low-speed pressure adjustment is the decisive feature of the Variant 3. In this absorption area the handling of the vehicle is greatly influenced. An increase in the damping force supports the vehicle even during compression, thereby preventing pitch, roll and notably improving cornering. The compression characteristics are adjusted utilizing a new, patented valve at the lower end of the damper casing.
http://www.6speedonline.com/forums/997- ... ter-5.html
Re: Bilstein PSS10 vs. KW Variant 3
Δημοσίευσηαπό Johny Mps3 την Δευτ Μάιος 10, 2010 13:00
Κατ αρχάς στο θέμα το ρυθμίσεών πρέπει να βρείς 'μάστορα " να τις ρυθμίσει σωστά και ειδικά στην ΕΛΛΑΔΑ για να μην σκορπίσει το αυτοκίνητο και αγοράζεις ημίμπαρα και ημιαξόνια . Από κει και πέρα δεδομένου οτι τα πάντα ειναι διαφήμιση και marketing και οι δύο θεωρουνται και είναι απο τις καλυτερες της αγοράς . Λεφτά να χεις να ρίξεις και custom ohlins ...φτίαχνεις .
Πάντως για το mps 3 (bk14) δεν υπάρχει pss10 !
ΞΥΠΝΑΤΕ ΕΛΛΗΝΕΣ ......ΧΑΝΟΜΑΣΤΕ
http://www.youtube.com/watch?v=tgSkADFE ... re=related
Johny Mps3
0,5 Bar
0,5 Bar
Δημοσίευσηαπό dgiannitakis την Δευτ Μάιος 10, 2010 13:12
Απ' ότι φαίνεται δεν υπάρχει επιλογή για το MPS 3...
http://www.roadandtrackbyohlins.com/en/product-range/
Δημοσίευσηαπό Johny Mps3 την Δευτ Μάιος 10, 2010 14:22
dgiannitakis έγραψε:Απ' ότι φαίνεται δεν υπάρχει επιλογή για το MPS 3...
imsorryyy ΕΙΠΑ ...CUSTOM . Κατα παραγγελία !!!!
Ψήνεσαι ; 3500 ευρώ συν φπα -τοποθέτηση !
Johny Mps3
0,5 Bar
0,5 Bar
Δημοσίευσηαπό dgiannitakis την Δευτ Μάιος 10, 2010 19:05
Johny Mps3 έγραψε:
Είναι η διπλάσια τιμή από τις αναφερθείσες οπότε ξεφεύγει το πράγμα...
Δημοσίευσηαπό Nikos76 την Δευτ Μάιος 10, 2010 19:53
Μιας και το κόστος σε κάθε προαναφερθείσα περίπτωση μόνο ευκαταφρόνητο δεν είναι
και επειδή οι καιροί είναι χαλεποί σκέφτομαι να προχωρήσω σε αγορά απλών αμορτισέρ
τα οποία συνάμα δεν θα μεταβάλουν το εργοστασιακό ύψος του οχήματος.
Δυστυχώς το τελευταίο αποτελεί μεγάλο πλεονέκτημα διότι η Ελλάδα όπως πολύ καλά
ξέρουμε δεν προσφέρεται για χαμηλά αμαξώματα.
Αλλά και το πρώτο επιχείρημα δεν πάει πίσω... με 200-250 κατοστάρικα κάνω μια δοκιμή
και αν το αποτέλεσμα δεν λάβει θετικό πρόσημο τότε δεν θα έχω χάσει πολλά.
Nikos76
Δημοσίευσηαπό dgiannitakis την Δευτ Μάιος 10, 2010 20:01
dgiannitakis έγραψε:Ποιά από τις δύο επιλογές προτιμάτε και για ποιούς λόγους; ;)
Εν τέλη, στο άνωθι ερώτημα ουδείς απάντησε... ;)
Δημοσίευσηαπό konstantinos xiros την Δευτ Μάιος 10, 2010 20:05
Φιλε Νικο εγω εαν ημουν σε θεση να βαλω προγραμμα στο αμαξι μου σιγουρα θα εβαζα μια καλη αναρτηση γιατι την εχει αναγκη το αμαξι.ΔΙΑΦΟΡΕΤΙΚΑ θα το σκεφτομουνα για προγραμμα γιατι εαν δεις οταν πατας γκαζι ποσο σηκωνεται η μουρη θα τρομαξεις.
konstantinos xiros
Μοντέλο Αυτ.: mazda 3 mps
Δημοσίευσηαπό Nikos76 την Δευτ Μάιος 10, 2010 20:14
Κωστή δεν αμφισβητώ τα λεγόμενά σου, το αυτοκίνητο ήδη σηκώνει σούζες και
το τιμόνι κάνει τρελά, αλλά έχεις δει τα αποτελέσματα αυτής της φτηνής λύσης;
Όλοι offtopic βγήκαμε... εκτροχιαστήκαμε σαν όχημα σε στροφή με λάθος αναρτήσεις!
Nikos76
Δημοσίευσηαπό Nikos76 την Τρί Μάιος 11, 2010 11:23
Έκανα λάθος για το θέμα της τιμής των απλών αμορτισέρ... ότι υπάρχει για τα δικά μας
δεν κοστίζει κάτω από 700 ευρώ. Οπότε μάλλον καλύτερα να δώσεις τα διπλά και κάτι
και να πάρεις κάτι ολοκληρωμένο, παρά τα ημίμετρα.
Προσωπικά (για να έρθουμε και στο θέμα του τόπικ) αν ήταν να αγοράσω σήμερα
ανάρτηση μάλλον θα πήγαινα για την KW και τούτο διότι έμαθα ότι μπορείς να κρατήσεις
το όχημα στο ύψος του, αν το επιθυμείς.
Έχω πάρει μια μικρή γεύση για το πως συμπεριφέρονται και οι δυο αυτές αναρτήσεις στα
οχήματά μας, χωρίς όμως να διαπιστώσω κάποια αξιόλογη διαφορά μεταξύ τους, για μένα
είναι το ίδιο καλές.
Για custom λύση των 3500 ευρώ θα την σκεφτόμουν αν έτρεχα σε αγώνες, όχι για τον δρόμο.
Nikos76
Δημοσίευσηαπό Nasos Mazdaspeed 6 την Τρί Μάιος 11, 2010 14:11
το θεμα της αναρτησης πολλες φορες ειναι δικοπο μαχαιρι!μπορει να παρεις την καλυτερη και να βγαλεις ολα τα σφραγισματα σου η να δημιουργησεις αν δεν εχεις!
οι PSS10 αν ειναι οντως καλυτερες απο τις 9 δεν νομιζω να υπρχουν καλυτερες μετα στον ανταγωνισμο.τι ρυθμισιμοτητα εχουν αυτες?
γελπιζω για διαθεσιμοτητα να βγαλουν και για τα Mps 3-6 !βεβαια εδω η HOT BITS η η ΚW πχ ακομη περιμενουμε εμεις οι 6αρηδες shotupi
Δημοσίευσηαπό Johny Mps3 την Τρί Μάιος 11, 2010 14:33
Υπάρχουν ΚΑΛΥΤΕΡΕΣ και ΑΚΡΙΒΟΤΕΡΕΣ όπως η PSS 16 (Ηλεκτρονική ρύθμιση) .Το θέμα είναι οι kw v3 τουλάχιστον σε mps 3 αποτελεί ίσως την καλυτερή επιλογή και με κόστος λίγο κατω απο 1400 ευρώ απο ΓΕΡΜΑΝΙΑ με μεταφορικά και χωρίς τοποθέτηση . Τα αμορτισέρ του εργόστασίου πάνε γυρω στα 750 ευρώ με ΦΠΑ και χωρίς τοποθέτηση αλλά και χωρίς τα ...παρελκόμενα (ελάτηρια- top mount κτλ μιάς kw ή bilstein ) οπότε ...όσοι ...έχοντες προσέλθετε !
Johny Mps3
0,5 Bar
0,5 Bar
Δημοσίευσηαπό diMiPS την Τρί Μάιος 11, 2010 22:39
εγω απο οτι εχω καταλαβει τοσα χρονια δεν παιζει τοσο ρολο το τι θα βαλεις οσο το ποσο αυτο που θα βαλεις
Α) ειναι καταλληλο για το αυτοκινητο σου και την οδηγηση που θελεις να κανεις και
Β) θα στο ρυθμισουν σωστα και θα στο φερουν στα μετρα σου
τι να το κανεις να παρεις την πιο ακριβη σουπερ ντουπερ ποιοτικη αναρτηση αν δεν ταιριαζει στο χαρακτηρα του αυτοκινητου και δεν ρυθμιστει καλα.
οπως ειπε και ο Γιαννης το θεμα ειναι να βρεις τον ανθρωπο που θα σε συμβουλεψει και θα ξερει να τη στησει στο αυτοκινητο σου
αλλιως ειναι να σου πει καποιος που ξερει "παρε αυτη " και να τη φτιαξει γιατι θα ξερει τι χρειαζεται το αυτοκινητο και αλλο να παρουμε εμεις οποια μας αρεσει απο τα reviews και να περιμενουμε να δουλεψει.
Δημοσίευσηαπό Johny Mps3 την Τετ Μάιος 12, 2010 12:37
Το θέμα είναι οτι στην ΕΛΛΑΔΑ οι έμποροι ...βαφτίζονται από μόνοι τους .....ΤΕΧΝΙΚΟΙ -ΤΕΧΝΙΤΕΣ -ΕΙΔΙΚΟΙ !!! Οπότε ο ειδικός που έχει μεγαλυτερο κερδός προώθει ως καλυτερή αυτή που θέλει ! ;)
Johny Mps3
0,5 Bar
0,5 Bar
Δημοσίευσηαπό tom την Τετ Μάιος 12, 2010 14:01
Καλησπερα σε ολους.
Εχω μια ερωτηση η οποια σε μερικους ισως να φανει αστειο.
Εαν καποιος στειλει e-mail στο εργοστασιο τις mazda και ζητηση βοηθεια οσον αφορα την αναρτηση για after market προιον,τι πιστευετε:
α.θα γελασουν
β.θα απαντησουν
tom
